83 Fuel Gauge Sending Unit
Car: 83 Z28
Engine: SBC 406
Transmission: TH350
Axle/Gears: Ford 9 " 3.89
I have an 83 Camaro with a fuel gauge issue. Its pegged past full. Took the dash apart and its not stuck or hanging up. I disconnected the pigtail connector going to the tank, touched the wires together from the gauge end and it did not drop to empty. I then used the volt meter set for ohms and touched the ends of the sending unit gets nothing on the meter. It displays 1 possibly meaning a fault in the sending unit. The fact the gauge didn't drop down to empty while testing the gauge end is baffling. Bad gauge and sending unit or am I missing something?? Also I cant find a new sending unit for this year either. Carbed motor, not a crossfire model. Any advise is greatly appreciated,
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
Just Fueling Around
Ground the purple wire.
Does that make the gage go to E?
Happy Racing!
Help Combat Global Cooling — Accelerate As Fast As Possible
Car: 83 Z28
Engine: SBC 406
Transmission: TH350
Re: 83 Fuel Gauge Sending Unit
Yes. The gauge is ok after checking things out. The sending unit is shot. Thanks for the reply!
Car: 1983 Z28 Crossfire
Transmission: 4 SP Auto
I have a similar issue. Replacing the tank and pump on a 1983 Crossfire and need to replace the sending unit also. Looking at buying the hanger/ sending unit from an 85 to 92. They are very similar. Threaded connection on the fuel feed line that I think we can ignore and just slip the hose on the line and clamp. But need to know if the sending unit is the same resistance as the 83. Looking at buying this one..
https://www.ebay.com/itm/Fuel-Gas-Ta....c100752.m1982
Not sure what your hanger looks like for the carb motor. How many lines, etc. But I have been digging around and found that the gauge sending unit part looks to be the same for many years. 0 ohms at empty and 90 ohms at full. If the hanger is too different for you to use the whole thing you should be able to take the gauge sending part off any year new hanger and adapt it to yours. It is mounted about half way up the fuel return line...again not sure what yours looks like.
Found this image on here. Shows the sending unit for an 87 and my service manual shows the same values for the 83.
file:///C:/Users/HP/Downloads/Pages%20from%201987%20Chevrolet%20Camaro%20Service%20Manual_Gauge%20Schematic%2002.pdf
I am going to get this one and a pump for my year and make it work.
I am having same issue I need a fuel sending unit for a 1982 camaro z28 CFI cant find anywhere!! just wondering if anyone was able to make the one for other years work?? any help would be greatly appreciated!!!
ThirdGen84Coupe
Aftermarket Product Review
Feb 17, 2020 11:56 AM
