1986 Trans AM pop up headlight replacement
Old May 16, 2021 | 08:59 AM
kingbowl93's Avatar
My 1986 Trans AM's driver side pop up head light has started to misbehave so I removed the motor to look into the matter. I have heard about the rebuild kits online, such as replacing the internal bushings and plastic gear with a brass or aluminum unit. I do not see many kits advertised for the pre 87 cars. After pulling the motor out I noticed it looks like the motor is "sealed" and not serviceable. See attached pictures. I firmly believe the internal gear is stripped on the inside based on how the headlight is erratically functioning. ( it goes up halfway, or the motor actuator will continuously run, etc). Can someone tell me if I must replace this motor as a whole or am I supposed to drill out the rivets holding the motor together to gain access to the gear and bushings?
Old May 21, 2021 | 06:03 PM
1989karr's Avatar
Engine: 3.4 / 5.0
Transmission: 700-R4
Axle/Gears: 3.42 / 3.42
Re: 1986 Trans AM pop up headlight replacement
Check out Top down solutions as he has parts to fix the order headlight motors.
Headlight Motor Kit: 82-86 Firebird or Fiero
  • Brand: TDS
  • Product Code: 508210
Old May 21, 2021 | 06:06 PM
1989karr's Avatar
Engine: 3.4 / 5.0
@lonsal
LGS_18
Jun 26, 2017 09:16 AM
redfirebirdman8
Jun 21, 2007 05:50 AM
cooltc2004
Oct 1, 2005 01:04 PM
1990GTA
Feb 26, 2003 11:15 AM
deadtrend1
Oct 5, 2002 08:11 AM
