Help. Fuel pump not priming
Fuel pump not priming. Will crank but won't start 1987 Ford Ranger XLT 2.9 Lt 6 cyl truck. Had a leak so replaced water pump then it would not start just crank over and fuel pump won turn on when key is turned to on position. Replaced fuel pump relay. Didn't help
Re: Help. Fuel pump not priming
My best suggestion will be to find a Ford truck forum where the people will know a lot more about your Ford than we will. The one and only bit of info I know is that some Fords (not sure about trucks though) have an "inertia" switch (crash switch) to kill the fuel pump in case of an accident, if your truck has one it could have gotten activated.....
