Is my Fuel pump bad?
Old Jan 9, 2008 | 04:13 PM
Cambridge205's Avatar
Car: 89 GTA
Engine: L98 350
Transmission: Swapped to a T-5
I tried to turn on the fuel pump today to see if it will work. But when I turned they key to the on position I heard the relay click but no fuel pump. So I tried putting 12V to the G terminal on the ALDL and I heard the fuel pump relay click again but no fuel pump. I thought this was supposed to bypass the relay and just turn on the fuel pump?? Anyways I'm thinking my fuel pump is bad. So I'm coming here to see if I missed any thing. Also the car's front end is on jack stands would this make it so I cant hear the fuel pump or the pump not turn on??
Old Jan 9, 2008 | 06:10 PM
87zjeff's Avatar
Axle/Gears: '01 3.42 10 bolt
Re: Is my Fuel pump bad?
get a fuel pressure guage and attatch it to the schrader valve and you remove all doubt.
Old Jan 9, 2008 | 06:18 PM
Car: 89 GTA
Engine: L98 350
I disconnected the fuel lines, and nothing came out when I tried to turn the pump on. So the fuel pump is bad... Would that also cause the car to die some times while driving?
Old Jan 11, 2008 | 07:14 PM
MP81's Avatar
Car: 2007 Cobalt LT
Engine: M62'd 2.2L L61
Transmission: 4T45E 4-speed Automatic
Axle/Gears: Stock
Yes.
Old Jan 11, 2008 | 08:15 PM
Steve86TA's Avatar
Car: To many to list
Have you checked the fuel pump fuse?
Old Jan 13, 2008 | 11:34 PM
Car: 89 GTA
Engine: L98 350
The pump was bad, and the fuse is good. I hate taking the gas tank out! If anyone has to take the tank out follow the repair book directions and if you still cant get the tank out the axle has to be lower or the car has to be higher. Height is key to getting it out.
But thanks for the help and I hope this fixes the dieing once in a while problem.
Old Jan 21, 2008 | 11:34 AM
john1784h@yahoo's Avatar
happened to me too, anyone know why the fuel pumps go on these cars? i got my tank out and the everything, dont wanna put it back together and lose another fuel pump....they aint cheap. If anyone can help please do!
Old Jan 21, 2008 | 11:36 AM
MP81's Avatar
Car: 2007 Cobalt LT
Axle/Gears: Stock
They overheat.
Old Jan 21, 2008 | 11:44 AM
BluFBdy's Avatar
Car: 89 Camaro RS
Engine: 355 SD TPI
Transmission: WCT5
Axle/Gears: 3.08 Posi
dont worry im in the same boat i just had the recent joy of doing a fuel pressure test on my tbi and realizing that its shot so i get to drop the rear and pull the pump too lol
Old Jan 21, 2008 | 01:50 PM
Rayzor32's Avatar
Car: '89 IROC-Z
Engine: 355
Transmission: 700r4 edge 3000 stall
Axle/Gears: 9-bolt 3.73
yeah never run below 1/4 a tank or youll kill the pump faster
Old Jan 21, 2008 | 03:18 PM
Car: 89 GTA
Engine: L98 350
It really is not that bad as I said car height is key to making it so much better.
Also if your always replacing them like monthly look at the valve under the gas tank and next to the other fuel lines that come out. It can get clogged and that puts a lot of strain on the fuel pump. I'm replacing mine because I broke it when I tried to take the hose off it. But I found a way to make it work till the replacement comes. By clipping off the little wings and filing them down to attach the hose back on it for now. However I have no idea how to test them...
Ill post the part number once I get it to make sure its the right part.
Glowsock
Jul 24, 2025 03:15 PM
mustangman65_79
Apr 14, 2017 05:37 PM
Bryan F
Aug 18, 2015 02:28 PM
Winchester1094
Aug 18, 2015 10:23 AM
Newguy91rs
Aug 7, 2015 09:51 PM
