3 amp crank fuse
Car: 83' Camaro, 88' TPI 350 Firebird
Engine: 383
Transmission: th350
Axle/Gears: 12 bolt w/ 5.13s or 4.56s
3 amp crank fuse
Is the 3 amp fuse labeled " crank " in the fuse block for the VATS system? I have a 1983 Camaro and this spot is without a fuse holder.
Re: 3 amp crank fuse
No... IIRC 1983 Camaros should not have the VAT-System.
Engine: 383
Transmission: th350
But that position in the fuse box would have been for the VATS?
No. VATS wasn't introduced until about 88 or so. The 83 wasn't equipped with "features from the future".
That fuse is involved with the TBI systems only. If your car is a carbed one, no fuse goes there.
