advice please Problems on new 87 TA
Old Oct 23, 2021 | 07:58 PM
pheonixthree's Avatar
I just bought a 1987 TA V8 AT4 Previous owner did work on it....sigh.
Engine has been swapped not sure if tranny was as well. It now starts and runs strong, But will stall when cold idling.
Don't hear any vacuum leaks.
cleaned fuel filter on carb. No change
No check engine light.
Speedometer works but not the odometer. Not a digital dash.
Will this be a cable issue or is it an electronic problem?
Old Oct 23, 2021 | 08:26 PM
OrangeBird's Avatar
Car: 1989 Firebird
Re: advice please Problems on new 87 TA
I'm not going to comment on the first part of your post, cause I know of no way to "clean" a fuel filter. They get dirty, they get replaced. Period.
Now as to your odometer, there is no cable involved, the speedometer/odometer are electronically run from the same signal from the VSS. Since your speedometer works and your odometer doesn't , the problem is with your odometer itself. Specifically, it's a well known problem of our cars that the plastic gears that roll the numbers disintegrate leaving the odometer inoperative. There are gear kits sold that can be used to repair the problem.....
Old Oct 23, 2021 | 09:34 PM
vorteciroc's Avatar
Top Answer: 1
Indeed, the Fuel Filters of the past...
Were intended disassembled, cleaned-out, and have a new Filter-Element installed.
Some Carburetors still use replaceable Filter Elements...
And most of the really large. high-flow Fuel-System Filters have replacement Fuel Filter Screens or Elements:
Old Oct 24, 2021 | 07:06 AM
OrangeBird's Avatar
Car: 1989 Firebird
Exactly, "And have a new Filter-Element installed"
From the OP's description, I didn't see the "New Filter-Element" mentioned, just something about "cleaned fuel filter on carb" , which is why I wasn't going there.........
Old Oct 24, 2021 | 07:43 AM
ironwill's Avatar
Car: 1986 IROC Z
Engine: 5.0 TPI
Axle/Gears: 3.23 Posi
Check the choke and fast-idle linkage for proper operation and adjust as necessary.
Old Oct 28, 2021 | 01:24 PM
1989karr's Avatar
Engine: 3.4 / 5.0
Transmission: 700-R4
Axle/Gears: 3.42 / 3.42
the gears on the odometer are notorious for breaking / seizing up. Since your speedometer is working im guessing your gewars are bad....
you could send the cluster out to a shop or order the gear yourself.........IMO its $$$ but worth to send to a shop..
Brad5116
Feb 26, 2016 11:10 PM
83 Crossfire TA
May 11, 2014 12:47 AM
kelham
Theoretical and Street Racing
Sep 22, 2006 03:17 AM
Nikole
17
Nov 21, 2004 10:23 PM
REBIRTH
Oct 27, 2002 12:23 PM
