headlight funny business
Car: '88 GTA
Engine: 355 SBC, AFR 195 heads, Stealth Ram
- My headlights have started popping up when I turn on the running lights. They don't turn on, just pop up. Headlights work as they should otherwise.
- The passenger headlight motor sits there and spins for several seconds after the lamp opens or closes and makes knocking noises. Driver's side is fine.
- The front side markers don't light up. I replaced every bulb in the car this year, so I know it's not that. I don't remember them ever lighting up.
Car: 90 Formula / T-tops
Transmission: MD8
Re: headlight funny business
1 and 3rd bullets sound like a wiring issue, 3rd one maybe loose ground / wire?
on 3rd bullet, I'd turn on and wiggle some wires and see if anything happens. next, get out a multimeter and see if they are getting power.
2 bullet sounds like classic headlight problem, may need to be rebuilt. google around this board, you will find what to do.
