Help wiring lights
Help wiring lights
So I decided it was easiest to pull the whole wire harness out and build my own for my application I’ve done everything but the lights I’m not sure how to wire them up does anyone have a diagram or anything to help I’m using the factory light switch and I wanna use the factory turn signal switch
Car: 92 Camaro RS
Engine: LO3
Axle/Gears: stock
Re: Help wiring lights
Here's an improved version found in the How To section on here
Upgrading Headlights For Your Third-Generation F-Body - ThirdGen.Org
NufNuffZ28
Oct 8, 2014 07:50 AM
