1988 Delco UX1 Radio 1606635 works but not with cassette
Old Nov 27, 2021 | 11:51 PM
Spankyty's Avatar
Car: 1988 Camaro Sports Coupe
Engine: 305 5.0L V8
Hi, new here hope this is the spot for this.
So I have a Delco radio I'm pretty sure it's the 1606635 one but who knows. It has the equalizer, RPO UX1 for 1988 Camaro.
I read the forums because I was not getting sound out of the right side speakers. I saw it was the 3x 1uF green caps. I replaced em and the right side speakers worked! There is some noise but whatever. That's not the issue I'm having.
With using the am/FM radio, everything works. Here comes the other issue. When using the cassette, I don't get sound out of the left speakers. So I fixed one issue with the FM/am radio not outputting to the right speakers but now using the cassette the left speakers don't work? Is there an amp for the cassette? Is it an electric issue or mechanical? I really don't want to remove the new thermal paste I put on. I used high quality brand and it comes in a tiny tube.
Old Nov 28, 2021 | 11:21 AM
John in RI's Avatar
Car: 1984 Camaro Berlinetta
Transmission: T56 6-speed
Axle/Gears: 4.11 LS1 Rear End
Re: 1988 Delco UX1 Radio 1606635 works but not with cassette
The problem will be due to the cassette mechanism itself and you can remove the cassette mech without dismantling the rest of the radio. The cassette sends it's own Left and Right output to the 2 AMPs in the head unit and the Left channel is ( for what-ever reason ) not sending the LEFT channel output from the cassette mech to the AMPs as it should. I don't know 'off the top' what wires the Left and Right from the cassette to the AMP are, but they will be part of the larger plug of the 2 plugs that connect the cassette mechanism to the radio itself. ( the smaller plug control the EJECT and SEARCH buttons on the faceplate. )
Old Jan 7, 2022 | 06:44 PM
Spankyty's Avatar
Engine: 305 5.0L V8
It works now for some reason? Maybe just dirty
Old Aug 13, 2023 | 05:36 PM
Spankyty's Avatar
Engine: 305 5.0L V8
Hello again. It seems this was an intermittent issue. It worked when it felt like it but now, it completely doesn't work. I did a few things to try and make it work:
  1. I replaced the left roller since it was broken. (All I had was a slightly smaller roller to replace it.)
  2. The cassette head was replaced with another gm head. (Dunno what radio it came from.)
  3. Aligned the head better with the small nuts holding the head reader on.
Unfortunately, none of this fixed the issue. I still do not hear left channels with cassette. What I am going to try and do now is bypass the head with a cut-up aux cable. (I will put a cassette in to make it turn cassette mode.) If this works I will update but if anyone else has had this problem and fixed it please let me know so I don't have to keep wasting my time. Thanks!
Jadelutis
Car Audio
Jun 20, 2020 12:54 PM
TrueIroc
Car Audio
Jul 22, 2013 12:20 PM
larry2365
Car Audio
Aug 1, 2006 12:31 AM
JohnS
Car Audio
Mar 4, 2005 06:37 PM
MasterEvilAce
Car Audio
Mar 3, 2004 05:05 PM
