hit pothole,now radio won't play
Car: 2004 Nissan 350Z
Engine: 3.5 V6
Transmission: 5 speed auto
I thought I just has a loose connection on one of my speakers, but i tightened up all the speakers and it didn't help any. my speakers sound perfect when i play a cd, but when i turn on the radio the speakers sound horrible! could i have knocked loose the internal antenna? or something else? Thanks
Car: 1991 Camaro RS
Engine: 357cid
Transmission: T5 Swap
Axle/Gears: 10bolt 7.5" 3.23 soon to be 3.73
pot holes = bad... avoid them at all costs... my antenna used to be loose on the car.. get a wrench and tighten it if you need
Engine: 3.5 V6
Thanks, i pulled the cd player and tightened everything, sounds pretty good so far, just a little static, but not bad. i hope it doesn't turn off everytime i hit a pothole. I really need to replace my shocks and struts, i guess i have a good reason to do it now
Car: 2000 Trans Am WS6 (Black)
I thought if the shocks were worn the car would be softer, as in the springs would bounce the car further up and down, and the struts are used to slow the spring movement... I didn't know that the struts actually helped prevent bottoming out... I think that's more of a spring issue.
Car: 1991 Camaro RS
Engine: 357cid
my spraings are dead on 4 corners but my shocks in the rear are new..... the front end bottoms out all the time... the springs just keep the car up the shocks and struts slow the movement
Engine: 3.5 V6
lol, yeah my car bounces down and bottoms out everytime i go over speedbumps, i hate to have to baby my car over them and then you still hear your car scraping, i sometimes think about just flooring it and ramping the damn things!! now my radio sounds good, but my amp just blew
luckily my girlfriend has an old MTX amp i can use until i get some $$$, i just spend $200 on steering parts.
luckily my girlfriend has an old MTX amp i can use until i get some $$$, i just spend $200 on steering parts. Supreme Member
Car: 1991 Camaro RS
Engine: 357cid
i wouldnt try to "ramp" them cuz the suspension sill delfect and your body will not go up but instead go straight into the speed bump
Hotrodboba400
Dec 10, 2019 07:07 PM
90formulaVortec
Sep 8, 2015 12:42 AM
