Do i need to swap dashboard
Car: camaro
Engine: 350 tpi
Hi i have a 1985 camaro that was originally a carburated 305 that im swaping a 350 tpi into. do i need a 350 tpi dash and wiring or can i just use stock 305 dash? Thanks
Car: '83 Firebird (T/A Clone)
Axle/Gears: 10-bolt/3.73 ..
Re: Do i need to swap dashboard
You'll have to swap the ECM that's under the dash...
Car: 1990 firebird,1989 Iroc z,1986 fire
Engine: 3.1lt,5.7tpi,3.1mpfi
Transmission: auto,auto
Axle/Gears: 273?277
You might want to run a 87 engine harness and ECM. The 86 harness would probably work with the 87 ECM. The 88 is different and the 89 up have the vats in them.
Axle/Gears: 273?277
Would his dash harness have all the wires to make the fuel pump work? Also the 85 model year has a maf burn off relay mounted piggy back on the ECM. That was in the z28 and irocs with the 5.0 tpi
IROCZDAVE (88-L98)
Sep 19, 2006 07:38 PM
