Rear window defrost connectors
Old Jun 9, 2022 | 02:15 PM
dlinger's Avatar
Car: 1984 Z28 HO
Last year I noticed the wiring to my rear window defrost had burn off the insulation. I replaced it with some wire and connectors I had. I decided to try and locate some better connectors. I used the third gen search and google search but have not been able to locate them yet. If anyone knows what type of connectors they are I would appreciate it. Both say PED. One had 11 and one has 16 on it.
Old Jun 9, 2022 | 02:50 PM
Komet's Avatar
Car: 1989 IROC-Z
Engine: L98 350 TPI
Re: Rear window defrost connectors
Don't know the GM part number, but they appear to be insulated flag terminals.
Old Jun 9, 2022 | 05:52 PM
vorteciroc's Avatar
Top Answer: 1
It is way more common that people are looking for the Mating-Terminal (soldered to the Defroster Grid/ Contact on the Glass) to the Electrical Connector that you are looking for.
P.E.D. is just the GM Brand/ Logo from that era (Packard Electrical Division) for Electrical Connection Systems.
I don't believe those original Connectors are still available anywhere...
GM produces a "Universal" ACDelco replacement Pig-Tail, that may fit.
ACDelco: #PT2645
Otherwise, the only other option is probably to purchase an aftermarket Pig-Tail or Connector from a company like Dorman (produces the "HELP" product-line commonly seen in Auto-Parts Stores).
Old Jun 10, 2022 | 09:08 AM
dlinger's Avatar
Car: 1984 Z28 HO
Thanks komet and vorteciroc for your help. I will check into those connectors. I have to get rid of the yellow crimp on ones I installed, they are too much out in the open.
Old Jun 10, 2022 | 09:56 AM
battmann's Avatar
Engine: LG4 / turbo LQ4
Transmission: 700R4 / 4L80E
Could you possibly re-cover the braided wire with some kind of loom or even a long piece of heat shrink tubing?
Old Jun 11, 2022 | 08:19 PM
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Axle/Gears: BW, 3.27
The connector at the other end (of the strut) should fit and its much more common. That w/ new wiring/grd terminal. Or maybe cut the OE connectors off and solder some new wire in place.
72buickgs
Oct 13, 2021 06:52 PM
Bonj87
Sep 9, 2021 02:51 PM
Saxondale
Feb 7, 2016 12:51 PM
x007
Aftermarket Product Review
Aug 19, 2005 07:05 PM
TunedPort 335
Aug 15, 2004 10:36 PM
