Turn signal flashes yellow on dash
Car: 1989 RS Convertible
Transmission: 5 Speed Manual
My first post! I have a 1989 RS Convertible. The left turn signal flashes yellow on the dash. The right, green.
All of the bulbs seem to be working. Any clues?
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: Turn signal flashes yellow on dash
Are you referring to the film
being gone in cluster ?
The Green-Gel Lens has most likely fallen out of the Instrument-Cluster Assembly.
Similar Green-Gel Lenses can be seen over the Signal-Light Indicators, in the Image below:
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Axle/Gears: BW, 3.27
OE's are round and about nickel size. They fall off easy sometimes when the bezel/lens is removed. It could possibly be lying in the cluster.
That makes sense. I thought it was trying to notify me I had a bulb out or something was amiss but then I realized it was 33 years old. Thanks for the feedback!
compuwiz1937
Aug 31, 2006 10:55 PM
