Braided Transmission lines shorting
Old Jun 23, 2022 | 02:05 PM
VikingCamaro's Avatar
Car: 1988 camaro
I just got done redoing an oil pan gasket and changing over my pulleys, now when I go to start my car it clicks and smoke rises from my braided steel transmission lines, I checked with a multimeter and they are grounded to the body and I have no wires to my transmission, I also have no ecm wires only wires that control the lights, and the gauges. I can not figure out why the lines are shorting out. Any help is appreciated thanks.
Old Jun 23, 2022 | 03:46 PM
ironwill's Avatar
Car: 1986 IROC Z
Engine: 5.0 TPI
Axle/Gears: 3.23 Posi
Re: Braided Transmission lines shorting
It sounds like those trans lines are acting as the chassis ground for the engine/starter. Check to make certain you have a proper ground strap from the block or head(s) to the frame.
Old Jun 23, 2022 | 03:52 PM
Car: 1988 camaro
you were right I realized I hadn’t tightened the ground, did that and it worked fine. Thanks.
Old Jun 23, 2022 | 06:07 PM
vorteciroc's Avatar
Top Answer: 1
Grounding is very often overlooked, however is actually the "More" Important side of this Circuit.
Old Jun 23, 2022 | 06:19 PM
Gordon G E's Avatar
Car: Got me a nice little '86 Z28.
Engine: A brand new 350 with a forged lower
Transmission: 5 speed, TKO600.
Axle/Gears: 10 bolt 373 modified zexel.
That happens alot. Had a friend who burnt up the trans lines in a Nova. Same thing no ground connection. Don't be surprised if the lines start leaking. They are rubber hose covered with the steel braid. Even Russel hose is that way.
spills
Carburetors
Feb 27, 2006 08:11 PM
JeffW
Aftermarket Vendor Review
Jun 30, 2005 11:50 PM
MechCD
Aftermarket Product Review
May 5, 2005 10:09 AM
pandorafowler
Apr 29, 2005 09:51 PM
