Voltage gage flickers with turn signal
Old Jul 11, 2022 | 11:33 AM
danderson's Avatar
Hey guys,
I'm having an issue with my '91 (305 TBI) where the voltage, fuel, and aftermarket coolant temp gage flicker with the turn signals (tach doesn't work , bad board; VSS is disconnected from previous owner - wrong connector), and drops slightly when I turn the headlights or cooling fan on. I checked negative on the battery and cleaned chassis to body ground yesterday; are there any other body grounds that I should check that are prone to cause these specific issues?
1988iroc350tpi
Nov 25, 2014 09:38 AM
86firebirdroar
Jul 23, 2014 11:24 PM
jazzdadss
Oct 12, 2011 01:38 PM
