AC Compressor Relay location
Old Jul 20, 2022 | 09:14 PM
DGGM92Camaro's Avatar
Car: 1988 Camaro IROC-Z
Engine: 5.7 TPI
Working on an 88 IROC with the 350 tpi setup. Where is the ac compressor relay, internet shows nothing. Also code 33 and 36 keeps popping up and the car runs like crap. MAF sensor I guess? Any help is appreciated, thank you
Old Jul 21, 2022 | 05:07 AM
OrangeBird's Avatar
Car: 1989 Firebird
Re: AC Compressor Relay location
Hi DGGM92Camaro,
The reason you can't find anything is that the 8 cylinder cars did not have an AC compressor relay, that was a 6 cylinder thing only. If you look at this diagram, only VIN S (the 6 cyl cars) had a relay, VIN E, VIN F, and VIN 8 don't.....
Old Jul 21, 2022 | 09:12 PM
Engine: 5.7 TPI
Thank you, couldnt find that diagram. Appreciate the help
Old Jul 21, 2022 | 09:17 PM
Engine: 5.7 TPI
Would it be possible to jump the high pressure switch to test if the clutch on the compressor works? The current issue is that it was recharged a year ago but now the compressor wont kick on when the AC is turned on
Henjoe
Apr 23, 2021 09:27 PM
Painmaster212
Aug 18, 2016 10:11 AM
roysatikas
Aug 18, 2014 07:54 AM
1987camarosport
Feb 10, 2007 06:23 PM
