Turn signal and gauges issue
Old Jul 25, 2022 | 01:22 AM
GTA1990's Avatar
Car: 1991 Trans Am
Engine: L31, LT4 hot cam
Axle/Gears: 3:42 LSD
Hi all
Car is a 91 trans am. On ignition the right turn signal is lit and the gauges (volts, oil pressure) move slightly but way lower than expected. On switching on the hazards the gauges then move in rhythm to the hazard flasher and only the right side turn indicator flashes. Same with the stalk; right side causes erratic gauge behaviour, nothing at all happens on the left
removed flasher bulbs and checked grounds in engine bay to no joy. Can’t see any obvious butchery
few posts on related issues suggest a bad ground. Going to be tracing the turn signal wiring this weekend (fun) but welcome forum input if aware of possible culprits
thanks!
Old Jul 25, 2022 | 10:17 PM
Rockguy's Avatar
Car: 88 IROC-Z
Engine: 5.7 TPI
Re: Turn signal and gauges issue
Ground issue was my first thought as well.
Old Jul 26, 2022 | 04:18 PM
GTA1990's Avatar
Car: 1991 Trans Am
Yeah guess I’ll be probing the turn signal circuits this weekend. Urgh…
Old Jul 26, 2022 | 04:50 PM
Rockguy's Avatar
Car: 88 IROC-Z
Engine: 5.7 TPI
Let us know what solves it. Good luck.
Old Jul 30, 2022 | 08:05 AM
GTA1990's Avatar
Car: 1991 Trans Am
OMG. So turned out the gauge connectors were in the wrong locations - white one was at the bottom instead of at the top. On correcting all is well; well my left turn indicator doesn't work but that seems unrelated
I recall I found a diagram on here of gauge connector positions for a 1983 Trans Am and assumed they were the same...
Old Jul 30, 2022 | 10:48 PM
Rockguy's Avatar
Car: 88 IROC-Z
Engine: 5.7 TPI
Thanks for letting us know. This might help someone else who may have a similar problem. Glad you got it.
Shepp84Z28
Dec 29, 2014 06:47 AM
camaro86
Sep 17, 2005 12:18 PM
MoroteZ28
Oct 7, 2004 07:05 PM
IroczCamar0
Apr 14, 2004 02:07 PM
zee28
Jun 13, 2003 09:03 PM
