turning signal problems
Old Oct 6, 2004 | 05:21 PM
MoroteZ28's Avatar
Car: 1991 pontiac firebird
Engine: 305 V8 flo-pro exhaust
Transmission: automatic 700r4 4speed
Axle/Gears: stock 2.73's :(
ok my right turning signal was not working
whenever i would put the turning signal on there would be no light on the outside but on the gauges the turning signal would just light up but not blink, i bought new bulbs and i replaced them and they worked for like a minute then it stayed on again and now my left bulb doesnt blink either and my front driving light bulb blew so could that be the reason why my turning signals arent working because the front right driving light blew?
Old Oct 6, 2004 | 10:40 PM
Petes 84Z28's Avatar
Car: 1989 Firebird Formula
Engine: Internal Combustion
Transmission: Completed
Axle/Gears: ones that turn.
The driving lights are not connected to the turn signal wiring in any way.
Old Oct 7, 2004 | 08:40 AM
thunderstick's Avatar
Car: '91 Z28
Engine: L98 5.7L TPI
Axle/Gears: 323's
supposedly if the signals don't blink, one of the bulbs in the front/side of the car or in the back are bad... not in your gauges.
KAM
Old Oct 7, 2004 | 02:11 PM
Godti's Avatar
Car: Trans AM
Engine: 305 TBI
Transmission: 5spd
I have a similar problem, except that mine stops acting up when I bump the front right turning signal. SO Im guessing its a wiring issue.
Old Oct 7, 2004 | 07:05 PM
redbird_400's Avatar
Car: 89 Formula Firebird
Engine: 305 - Demon 525
sounds like your gonna have to spend some time tracking down wires. I believe if you turn your fog lights on, these light up as well, then if you activate the turning signal then turn on and off. I wouldnt be suprised if there is just some wire somewhere that is grounding out and causing it to fry...
Fronzizzle
Mar 18, 2019 08:29 PM
z28_AJ
Aug 27, 2015 08:59 PM
Fronzizzle
Aug 17, 2015 02:52 PM
Tony Ferrarri
Aug 11, 2015 07:59 PM
Fronzizzle
Aug 9, 2015 01:15 PM
