Cigarette lighter sparked, radio doesn't work
Old Aug 18, 2022 | 07:51 AM
Mspangler's Avatar
Car: 1991 Camaro RS
Engine: 5.7 Lt-01
Axle/Gears: 3:28
Ok so I have a base model 1986 Camaro. This morning when I turned it on the cigarette lighter sparked and my radio turned off. I have a kenwood radio that's wired to the original harness, and I checked the one fuse for the radio and theres a 15 in it. The car is completely off but when I touch the fuse to put the new one in it lights up. That would mean that there's a wire touching on the cigarette lighter right? Or do I have to buy a bigger relay or something to run the radio? Also can someone post a picture of an accurate fuse diagram please, all the ones on google are different, want to see what fuses I should actually be running.
Old Aug 18, 2022 | 12:35 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: Cigarette lighter sparked, radio doesn't work
IIRC, there are two fuses for the radio. One for the keep alive radio memory. And another that is from IGN+ switched to power the radio.
As for the lighter, same issue with my '92. Jiggle the push-in piece and it pops a fuse. That portion now resides in the console. Although the socket portion can still be used for DC invertors and such.
RBob.
Old Aug 18, 2022 | 02:46 PM
The fuse that powers both the cig lighter and the radio memory, as well as the "courtesy lights" (dome and footwell lights), is blown. It's labelled "CTSY".
Meanwhile, your cig lighter is AFU. Replace it before changing the fuse, as it will just blow a new fuse the same as it did the old one.
Hartmann
Apr 17, 2008 10:18 PM
f_body_4_life
May 21, 2005 01:31 AM
kretos
Oct 3, 2004 06:56 PM
mory
Aug 30, 2004 04:29 PM
white91formula
Sep 14, 2003 08:10 PM
