Adding power door locks
Old Sep 16, 2022 | 05:48 AM
MichiganWildcat's Avatar
Car: 1985 IROC Z
Do we know if the 85 IROC'S are pre-wired for power door locks and I just need the switches and actuators?
Thank you
Old Sep 16, 2022 | 09:27 AM
91banditt2's Avatar
Car: 1991 BandittII Firebird
Engine: 5.7 HSR
Axle/Gears: 3.27 9 bolt
Re: Adding power door locks
Thank you
Not the original owner I'm assuming? With it being an IROC I would of guessed that it would have the power door locks, could be a special order thing back in 84-85 original owner didn't want/need power door locks. As for the wiring some of it could possible be there but chances are there is none at all, GM could of used some wire harnesses that were made with all the available options because in the grade scheme of production it could be cheaper than workers having to spend time during the assembly process figuring out what the car needs as it's going through the assembly line. Your going to need to do some investgating as there's a chance you may need it all, lock switches, lock actuators and their linkages and small brackets to the door locks, relay and wiring. Start looking online for people parting out similar year cars to pull some of these parts from. There are some online sources that sell used parts for these car as well.
Frank's Pontiac Parts (frankspontiacparts.com)
Third Gen Bargain Barn (godaddy.com)
Home - Thirdgen Ranch
1982 - 1992 Trans Am Firebird Parts Home Page (fbodywarehouse.com)
AustinThirdGen.Org is a good source wire schematics
EDIT: These are the actuators,switches and key less entry that I just recently put in my 91 Firebird, so far these have very few operations but so far so good. FYI there is a left and right door switch
Amazon.com: Dorman 746-014 Door Lock Actuator Motor Compatible with Select Models : Automotive Amazon.com: Dorman 746-014 Door Lock Actuator Motor Compatible with Select Models : Automotive
Amazon.com: ACI 87277 Door Lock Switch : Automotive Amazon.com: ACI 87277 Door Lock Switch : Automotive
Amazon.com: ACI 87276 Door Lock Switch : Automotive Amazon.com: ACI 87276 Door Lock Switch : Automotive
Amazon.com: BANVIE Car Keyless Entry System for Central Door Lock with 4 Button Remote Control Transmitter : Everything Else Amazon.com: BANVIE Car Keyless Entry System for Central Door Lock with 4 Button Remote Control Transmitter : Everything Else
keyless entry help - Third Generation F-Body Message Boards
Old Sep 16, 2022 | 10:18 AM
Car: 1985 IROC Z
You're correct, I'm the 3rd owner, looking at the RPO list, this car is a customer order not a dealer order. Thank you for the links. I'll do some snooping inside the door and go from there.
bbsr72
Jul 23, 2012 11:46 AM
z28lnmn
Apr 30, 2011 07:44 AM
Skull88
Jan 29, 2007 07:13 PM
eddie jr
Apr 12, 2003 09:40 PM
