Wiper failure help
Old Sep 8, 2022 | 07:05 PM
88BLKTransAmGTA's Avatar
Car: 1988 Trans Am GTA
Engine: 5.7 L98
Axle/Gears: 3.77
Wiper failure help
My 88 GTA's wipers do not work anymore. Everything else on the multi function lever switch works washer control, cruise control, both blinkers just the wipers won't move. Fuse is good because It shares with the washer and it works. So what is the next thing that usually is the issue?
does my 88 have a wiper relay or is everything in the motor?
Old Sep 9, 2022 | 11:17 AM
topduarte's Avatar
Car: 92 Heritage Camaro Z28
Transmission: auto
Axle/Gears: 3.23 Limited Slip
Re: Wiper failure help
I believe it has a relay not 100% sure.
Old Sep 10, 2022 | 06:57 AM
Engine: 5.7 L98
Axle/Gears: 3.77
Anyone have any help on this problem? I'm not trying to spend $200+ on a pulse wiper relay if that is not the problem
Old Sep 10, 2022 | 07:38 PM
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Axle/Gears: BW, 3.27
Have you removed the black cover on the wiper motor? Usual culprits, park switch, cracked circuit board/bad capacitor/s or that blue wheel/arm inside the cover. I believe the relay is built in to the wiper motor cover C.B.
https://www.thirdgen.org/forums/elec...tor-cover.html
Old Sep 17, 2022 | 04:49 PM
Engine: 5.7 L98
Axle/Gears: 3.77
Removed the wiper motor cover. It all looks good. No broken pieces or cracks. I also checked the power at the harness and it does have power.
Old Sep 17, 2022 | 05:01 PM
Motor housing ground probably failed
Run a ground wire from a screw on the motor proper, to the firewall
Old Sep 17, 2022 | 06:39 PM
vorteciroc's Avatar
Top Answer: 1
Relays....
HAHAHAHAHAHAHA!
B84
Aug 12, 2012 11:36 AM
Ob_one
May 15, 2011 09:43 AM
Makai
Aug 9, 2002 09:30 PM
GTA-88
Jan 6, 2001 06:48 AM
SHARP89RS
Jul 30, 2000 06:28 PM
