Rear Deck lid Hatch
Old Sep 16, 2022 | 03:55 PM
tylrdenny's Avatar
Car: 1989 Camaro RS Convertible
Engine: 5.0 L, 305
Rear Deck lid Hatch
So on my 89 Camaro convertible it seems like someone had Jerry rigged every bit of wiring. When I was replacing my latch pull down motor I found some wires twisted together with plugs on the end, the blue and white wires, it definitely doesn't look factory. I thought maybe it has something to do with the tonneau cover release since it doesn't work. The pull down latch works great now but I was wondering if anyone had a wiring schematic for the pull down latch for the convertible or any knowledge on what those wires are, thanks!
Old Sep 18, 2022 | 12:03 PM
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Axle/Gears: BW, 3.27
Re: Rear Deck lid Hatch
Not exactly the trunk schematic, but mostly correct. That small plug goes to the trunk light on the plastic panel. I think the blue wires go to a relay. Lon at TDS can clarify this better than me or wait for someone to chime in.
Old Sep 18, 2022 | 12:14 PM
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
My trunk pull down.
Old Sep 18, 2022 | 12:25 PM
tylrdenny's Avatar
Engine: 5.0 L, 305
Great! Thank you for that. Can you tell where those two blue and two white wires go?
Old Sep 18, 2022 | 07:07 PM
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Wht iwres to trunk light, blue to relay.
Old Sep 18, 2022 | 07:50 PM
tylrdenny's Avatar
Engine: 5.0 L, 305
Ok, thanks!
Old Sep 18, 2022 | 07:57 PM
tylrdenny's Avatar
Engine: 5.0 L, 305
Ok I found a good diagram, this is what I needed. Here it is if anyone else needs it.
Reddeath210
May 7, 2013 08:20 AM
nj88v6
Aug 21, 2001 05:22 AM
