Negative Battery Cable
Old Oct 1, 2022 | 11:42 AM
72buickgs's Avatar
Car: 1984 Trans AM
Transmission: 700-4r
1984 Trans AM 5.0 engine
I am looking for a part# for the negative battery cable, be it AC Delco or GM OR an aftermarket source.
Would 4SD25X be correct for AC Delco. I assume that "25" means 25 inches
Old Oct 1, 2022 | 01:28 PM
T.L.'s Avatar
Car: '83 Firebird (T/A Clone)
Axle/Gears: 10-bolt/3.73 ..
Re: Negative Battery Cable
I don't know the part number, but why not just order one for your year, make, & model? That's what I did...
Old Oct 1, 2022 | 02:40 PM
TTOP350's Avatar
Engine: 4++,350 & 305 CIs
If I was home I'd look it up in the gm parts book for ya
Old Oct 1, 2022 | 02:52 PM
battmann's Avatar
Engine: LG4 / turbo LQ4
Transmission: 700R4 / 4L80E
Here’s a picture of the factory negative battery cable in my 1984 TA
Old Oct 2, 2022 | 05:58 PM
72buickgs's Avatar
Car: 1984 Trans AM
I found the part# on the cable but searching that # reveals nothing. Off to Rockauto.
Old Oct 2, 2022 | 06:53 PM
Dens71TA's Avatar
Car: '82 Recaro T/A, '71 Trans Am
Engine: 305CFI/455HO
Transmission: TH700R4/M22
Axle/Gears: 3.23/3.42
GM part book lists number 12003646. It's a service replacement cable so it's not exactly like the original and also fits a few other GM vehicles. Discontinued in 2006 but
there is some new old stock still floating around.
AC Delco lists part number 4SD30X as a currently available replacement. Appears to be a reboxed aftermarket Standard Motor Products battery cable.
Old Oct 3, 2022 | 10:10 AM
72buickgs's Avatar
Car: 1984 Trans AM
Tkx for all the info guys. Much appreciated. I checked out Rockauto & 4SD25X s/b the correct cable. Somehow along the way a previous owner, damaged the threads on the cable "bolt" to the battery. Had to replace the battery (died) & the "bolt" would not gain enough catch to attache to the battery. Had to do some filing on the battery negative receiver.
Old Oct 3, 2022 | 06:13 PM
vorteciroc's Avatar
Top Answer: 1
Our Cars are lacking in the Battery Power Connections...
Now is a good time to upgrade.
If you are not in a situation where DIY will work for you...
Take a look at CE Auto Electric Supply.
They offer Custom Battery Cable Services:
72buickgs
Oct 3, 2022 06:23 PM
The_Phoenix
Jul 23, 2013 01:31 AM
Elthesh
Sep 24, 2007 06:51 PM
Slow89Iroc-Z
Jul 18, 2005 09:29 PM
