87 Firebird --Tachometer stopped working when distributor was replaced
Old Oct 31, 2022 | 05:03 PM
CL70's Avatar
Car: 87 Firebird
Engine: 383 Stroker
Axle/Gears: 373
Replaced previous distributor w MSD Ready to Run (8360). Engine is nearly new 383 Stroker but gauges in the car are original. Tachometer worked fine before the new distributor. Mechanic that installed the new equipment said that I should be able to find an interface part that would help those two devices communicate/work together. All connections are secure and mechanic did check with an external tach to make sure that it would work. I'm hoping that someone on this forum could steer me in the right direction... Thanks in advance!
Old Nov 11, 2022 | 11:10 AM
91banditt2's Avatar
Car: 1991 BandittII Firebird
Engine: 5.7 HSR
Axle/Gears: 3.27 9 bolt
Re: 87 Firebird --Tachometer stopped working when distributor was replaced
Did you ever figure this out?
Old Nov 11, 2022 | 11:34 AM
CL70's Avatar
Car: 87 Firebird
Engine: 383 Stroker
Axle/Gears: 373
I haven't had a chance to mess with it yet. I wrote to MSD and one of their online techs sent me this to try---
If you're using the tach output wire on the distributor the tach may not work. When using the 8360 an no ignition box you can connect the tach to the neg side of the coil.
64 ford
Jul 14, 2018 02:51 PM
camaro87-alex
May 8, 2011 03:15 AM
91birdman78
Jul 8, 2008 11:11 PM
speedlvr
Apr 28, 2001 08:48 AM
