Question
Old Nov 5, 2022 | 03:11 PM
markymac's Avatar
Question
Terminal?
Could anyone tell me what this went to. Brown lead wire. When i touch with a grounded test light i can hear a clicking sound under the dash
Old Nov 5, 2022 | 07:22 PM
aliceempire's Avatar
Transmission: T-5, TH350, T-5
Re: Question
Alternator? Looks like that old style connector
Old Nov 5, 2022 | 07:41 PM
Re: Question
Yup.
The red wire went to the output post, where the wire to the batt also went.
Old Nov 6, 2022 | 10:24 PM
markymac's Avatar
Re: Question
Thought alternator plug had a resister on the wire to the plug in?
Old Nov 6, 2022 | 10:33 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: Question
a/c compressor has a diode maybe that’s what you where thinking about.
Old Nov 7, 2022 | 06:14 PM
markymac's Avatar
Re: Question
So I would use the alternator wire and connect to the plug on the LS swap alternator plug?
Old Nov 8, 2022 | 06:37 AM
Re: Question
Depends on what alternator you use.
That connector is for the old 10SI model. Newer alternators use different plugs. Some "LS" alternators are controlled by the ECM. Some are not, but rather have internal voltage regulators like the 10SI did, but need different connections.
Details.
megan.artiaco
May 2, 2011 07:50 PM
Project: 85 2.8 bird
May 30, 2002 09:56 AM
pred1tor83
Jun 3, 2001 08:06 PM
