89 GTA Led headlights swap causing issues
Old Nov 3, 2022 | 06:18 PM
NORTHSLIDER's Avatar
Car: 79, 85, 87,91 TRANS AM'S
Engine: 455,305TPI,350TPI,350TPI
Transmission: MUNCIE, T-5, 700R4'S
Axle/Gears: YEP
I just got a set of LED headlights for my 89 GTA and after installing them now they won't go down. I tried manually moving them down and they won't let me get past half way before re-engage them to the up position. Did I fry the headlight control module somehow with the LED lights? Any help would be greatly appreciated.
Old Nov 3, 2022 | 11:06 PM
Buddy's Avatar
Car: '87 FIREGOOSE!!!!
Re: 89 GTA Led headlights swap causing issues
Have the gears ever been changed yet? I know when I disturbed my headlights the gears literally said "done". The plastic gears were literally powder.
Old Nov 7, 2022 | 10:00 PM
1965gp's Avatar
Are they bigger than factory style on the back of the light? If you can’t do it manually I would assume something is binding.
Old Nov 8, 2022 | 09:12 AM
scfbody's Avatar
Car: 1983 Z28, 1991 Z28 & 1985 TA
I'd disconnect the battery and try manually moving them up and down, check to make sure the wiring or the light isn't holding them up. Normally it will damage the headlight wiring before damaging the headlight motor if that is what is happening.
bryan623
Oct 9, 2014 10:36 PM
Sweet6
Exterior Parts Wanted
May 16, 2009 09:40 PM
kar83
Sep 26, 2005 12:45 PM
