Formula headlights go down but not up?
Old Nov 25, 2022 | 09:10 AM
Fuel an's Avatar
Car: 1989 Formula
Engine: 5.0
Axle/Gears: 2:73
Happy Day after Thanksgiving. Very odd. My headlights will go down, but will not go up. Also tired to raise them with the manual **** and doesn’t seem like they are moving and **** spins pretty freely, are the plastic gears just wasted, but why would they go down? I have searched the forums and google and cannot find anything with this symptom of going down but not up. Any help greatly appreciated.
Old Nov 25, 2022 | 11:54 AM
OrangeBird's Avatar
Car: 1989 Firebird
Re: Formula headlights go down but not up?
Most times, what you describe can be solved with this ;
https://www.top-downsolutions.com/he...ght-repair-kit
Old Nov 25, 2022 | 11:55 AM
blacksunshine'91's Avatar
Transmission: Pro-built 700R4
Why would they go down? Gravity. Have you opened up the case and looked to see what the gear teeth look like? There's an extremely high chance that either your gears are worn or the bearings have disintegrated. If you don't have much experience with it, it is a very easy fix to do. Lon at TopDownSolutions has the rebuild kits. Takes less than a half hour to do them both.
Old Nov 25, 2022 | 02:44 PM
TTOP350's Avatar
Engine: 4++,350 & 305 CIs
Most of the time the gears are fine, it's the little drive pucks that turn to dust. This shows a upgraded brass gear.
i have seen 1 car where the shaft was actually spinning inside the pressed on cast aluminum piece that helps drive the pucks. (Lower picture with crumbled plastic)
Old Nov 26, 2022 | 04:19 PM
Fuel an's Avatar
Car: 1989 Formula
Engine: 5.0
Axle/Gears: 2:73
I picked up some new motors at the parts store, that did the trick. Will order the kits and rebuild the original motors with new pucks. FYI, whoever rebuilt these wired the right motor incorrectly, had one light up and one light down. I switched the polarity and they both started working in sequence.
Robb Knight
Aug 29, 2008 10:40 PM
shuf
Jun 6, 2005 08:12 PM
JMan976
Jun 14, 2003 10:26 AM
FstBrd6point3
Dec 7, 2001 01:06 AM
