Bussmann RTMR Fuse/Relay Panel Help
Old Mar 22, 2023 | 06:49 PM
RJDin10isee's Avatar
Car: 1989 Camaro
Axle/Gears: 410 Yukon
Hello friends, first thread for me here, but I've been lurking for a couple months. I purchased an 89 a couple months ago that has been switched from TBI to Carb and was working on cleaning up the underhood wiring. I have seen where some people use the Bussmann RTMR boxes for relays and fuses and wanted to do the same because of it's modularity. Of course right now I just need fan and fuel pump relays (and maybe high speed HVAC fan, but a/c is deleted). There are two of these boxes that I have seen used, one with 2 internal busses and the other with only one buss on the fuse side. I currently have the 2 buss version and am struggling to understand how I can wire up the fan relay since it is negative trigger from the temp sensor, but then the fuel pump is a positive trigger from ignition. Is this possible with the box that I have since one buss is power and the other is ground? I messaged @vorteciroc about it, but I know we all have busy lives and I may have been a bit confused when I tried to convey what I was trying to accomplish. Thanks in advance for any help you guys can provide.
Bussmann / Eaton 15305-2-2-4 Front
Bussmann / Eaton 15305-2-2-4 Rear
Old Mar 22, 2023 | 07:06 PM
QwkTrip's Avatar
COTM Editor
Car: '89 Firebird
Engine: 7.0L
Re: Bussmann RTMR Fuse/Relay Panel Help
I think the B+ busbar is used for the high current switched power and not the relay control. You would still wire individual wires for relay field coils to control the relay on/off. The relay coils will not share wiring so you can wire one relay coil with high side switching, and the other relay coil with low side switching.
Each busbar has a max rated continuous current. Make sure the total current of all components together on that busbar do not exceed that rating.
Old Mar 22, 2023 | 07:37 PM
Car: 1989 Camaro
Thanks Qwk, but I have seen these boxes sold as pre-wired kits like this: LINK and they always say "relays can be positive or negative triggered, but not a mixture of both." I think that's where my confusion lies. I'm a decent parts-changer (I swear,) but I tend to overthink this wiring stuff.
P.S., your build thread was hours of enjoyment... The highs... the lows, it had it all.
Old Mar 22, 2023 | 07:46 PM
QwkTrip's Avatar
COTM Editor
Car: '89 Firebird
Engine: 7.0L
My guess is that's just a result of their design choices. They probably spliced all the relay coils to a common wire on one side. Since you're wiring yours from scratch then you can wire up your coils any which way you want.
That's real life right there! I had almost zero experience when I started that thread. I'll be honest, it was difficult for me at times.
Old Mar 22, 2023 | 08:12 PM
QwkTrip's Avatar
COTM Editor
Car: '89 Firebird
Engine: 7.0L
Wait a minute, I think I steered you wrong. Double busbar will have a common rail to all fuses and a common rail to all relays on terminal 86. All the switching will have to be on the ground side. You can't reverse polarity relays with flyback diode (and I would choose relays with flyback diode).
If you want to wire relay coils all individually then you'll not want a busbar on that side of power center. I think what you want is the style shown in Figure 4 of this document, https://www.waytekwire.com/datasheet/46343.pdf
Old Mar 23, 2023 | 07:57 PM
Car: 1989 Camaro
Thanks again @QwkTrip I've got the single buss RTMR on the way and might, just might be able to get this turd back on the road in the next couple weeks.
Old Mar 23, 2023 | 11:21 PM
vorteciroc's Avatar
Top Answer: 1
I am just catching up on PMs...
Thanks for Tagging me @RJDin10isee .
I see that QwkTrip has got you squared-away.
You are in good hands!
rusty vango
Jul 26, 2014 09:25 PM
Sisco
Aug 7, 2006 09:54 PM
pontiacsteve
Nov 23, 2005 01:27 PM
Quiet Bob
May 22, 2001 06:18 PM
ucbearcat
Feb 18, 2001 12:13 PM
