blown fuse to cooling fan
Old Nov 20, 2005 | 07:50 PM
pontiacsteve's Avatar
Car: 82 z28
Transmission: auto th350
Axle/Gears: stock
short circuit in cooling fan wiring
I have checked continuity from the cooling fan to the relay on my 86 trans am and it is okay. Every time I put a fuse in for the the fan motor it blows as soon as I turn on the key. Anyone ever had a relay go bad that would cause a short?
Old Nov 21, 2005 | 05:37 PM
firebirdjosh's Avatar
Car: 86 T/A
Engine: HSR 355
Axle/Gears: 2.77 posi
Relays probably won't blow fuses, dying fans will though.
Old Nov 21, 2005 | 06:38 PM
Car: 82 z28
Axle/Gears: stock
I have the wiring disconnected at the relay and it still blows fuses,so I am thinking it has to be something between the fuse box and the relay.
Old Nov 21, 2005 | 06:48 PM
Car: 86 T/A
Engine: HSR 355
That's the very definition of a pinched wire. Just track it down and repair it.
Old Nov 21, 2005 | 07:27 PM
Car: 82 z28
Axle/Gears: stock
I bought the car with a salvage title as a hobby project and the heater core had just been changed . The water pump was leaking and I changed it and the thermostat.I just got it running again and was working on the carb when I noticed the temp climbing and the fan not kicking on,which is what led me to check fuses. And here I am.I will check it out and let you know what I find. Thanks for the input.
Old Nov 23, 2005 | 01:27 PM
Car: 82 z28
Axle/Gears: stock
found the short,it was where the wire went through the firewall,so I ran a new wire and all is well for the moment. Now to a new thread that deals with carbs and adjusting
gta892000
Aug 11, 2019 11:16 AM
gta892000
Sep 16, 2015 12:37 AM
64goatman
Sep 9, 2015 01:09 PM
IROCZDAVE (88-L98)
Sep 2, 2015 08:49 AM
IROCZDAVE (88-L98)
Sep 2, 2015 08:43 AM
