Help identify terminal connector
Old Apr 18, 2023 | 07:40 PM
badtenant's Avatar
Car: 92 RS
Transmission: TKX
What GM/Delphi part number is this terminal? This wire is from a 4th gen fuse box...
Bill
Old Apr 18, 2023 | 08:07 PM
battmann's Avatar
Engine: LG4 / turbo LQ4
Transmission: 700R4 / 4L80E
Re: Help identify terminal connector
@vorteciroc would know I bet
Old Apr 18, 2023 | 08:14 PM
badtenant's Avatar
Car: 92 RS
Transmission: TKX
I'm counting on it!
Old Apr 21, 2023 | 10:22 AM
91banditt2's Avatar
Car: 1991 BandittII Firebird
Engine: 5.7 HSR
Axle/Gears: 3.27 9 bolt
Beat me to it, he would be who I would be asking.
Old Apr 21, 2023 | 05:09 PM
vorteciroc's Avatar
Top Answer: 1
Several questions:
-What Gauge Wire needs to fit the Terminal?
-Does the the "Back-Side" of the Terminal (The Side I can NOT see in the Images) have a Locking-Tang?
-What is the width in "mm" of the "Pad" that the Wire-Insulation is against (Looks like Wings on each side of the Wire-Insulation)?
Old Apr 21, 2023 | 05:28 PM
badtenant's Avatar
Car: 92 RS
Transmission: TKX
So I figured a few things out...
Just a bit of context...I'm trying to leverage the 4th Gen Fuse Box for my fans and fuel pump. I have a hotwire kit and just want to use this block to hold my inline fuse. So I'm just looking for the correct terminal However, the terminal from the hotwire kit fit in the block just fine and locked when I tried it. Just didn't have those fins on the side. Might be more trouble than it is worth. Some of those connectors seem to be hard to find...
Main Fuse Box: 12176369
Small Terminal: 12110717
Large Terminal: 12092556
Here is the breakdown from the datasheet:
Old Apr 21, 2023 | 06:47 PM
vorteciroc's Avatar
Top Answer: 1
I should be able to find a solution for you.
Please just answer the 3 short Questions that I asked you in Post #5
BytePaul
Jun 22, 2021 08:13 AM
91banditt2
Jan 25, 2020 11:46 AM
t/adreams
Mar 8, 2010 09:16 PM
305q_ta86
May 13, 2006 08:30 PM
Steve89GTA
Mar 24, 2003 12:10 PM
