87 iroc wipers problem
Hi I replaced the intermittentlwiper equipped column on my 87 with one from an 88 with a 2 speed switch they gradually stopped working replaced the fuse & used contact spray used to work sometimes if I reached under the dash & wiggled the fuse now nothing do I need to replace the manual wiper switch with an intermittent switch? Please help me take care of my baby. Thx
Car: 1992 Jeep Wrangler + a few more car
Engine: Gm 5.7 T.B.I with 1227747 ECM
Transmission: 700r4 DIY built
Axle/Gears: Ford 8.8/D30- 4:10 and lockers
Re: 87 iroc wipers problem
I would first test the fuse/socket. A poor connection = heat. Might have burned out that connector in fuse box. You will need to test for 12vdc past the fuse holder. A location at that fuse and then downstream of that fuse connection.
Well, here I am again sorry for not responding earlier fuse is good I should mention that I have replaced the column that has a non pulse switch the previous column has a pulse switch that be the problem? Thank you
Trying to apply a bit of logic to your problem, I'll start with the column swap. I do not happen to have the schematics in front of me for both the 87 intermittent and the 88 two speed wipers, but if it DID work when you first swapped it, and then "gradually stopped working", I'd say incompatibility is most likely NOT the problem.
So now we come to "Used to work sometimes if I reached under the dash & wiggled the fuse" . As JeepYJv8 has already said, this is absolutely an indication of a bad connection somewhere in the area where the wiggling was taking place, and in this case it's most likely the connectors in the fuse box that hold the fuse in place, or the wiring connecting to those little metal clips that hold the fuse.
