1984 Berlinetta turn signal/lights
Old May 16, 2023 | 09:49 AM
Talon1984's Avatar
Car: 1984 Camaro berlinetta
i have a 1984 berlinetta the headlights didn't work so i swapped the wires from the high beams to the headlights and vise versa for the high beams and ran a jumper wire from the headlights to the high beams and they all started working but doing so it made the blinkers stop working they all light up but dont flash i can hear the relays clicking tried swapping them out for relays that i know work and got nothing not sure if the blinkers are tied into the headlight wiring some how and when i switched them around it messed up the blinkers i cant find much online about the wiring for Berlinetta's and im not good with electrical at all so any help would be appreciated
Old May 16, 2023 | 11:25 AM
RedLeader289's Avatar
Car: 1983 Z28
Engine: 385 Fastburn
Re: 1984 Berlinetta turn signal/lights
Reverse everything you did for the headlights.
Then replace the headlights themselves. (very simple, can be purchased from rockauto or amazon)
Then replace the turn signal bulbs (which are most likely blown now).
Even if you can see the filament seemingly "whole" inside the bulb it can still be blown.
Do all that and you should have working lights. If I had to bet the low beam filament on your headlights was out to begin with and doing what you did simply made the low beams function in high beam mode perpetually.
Old May 17, 2023 | 11:20 AM
Talon1984's Avatar
there brand new headlights/high beams there led's not sure if that's also causing issues but ill switch everything back see if that fixes anything i also found a blue flasher relay under the dash not sure if that's part of the blinkers because there's relays inside the light module but the part num is 3218415
atgrazi
Apr 14, 2017 08:20 AM
cdoyle
Jul 21, 2014 05:34 PM
TPI TERR
Sep 24, 2006 01:27 PM
camarors8992
Aug 12, 2005 09:06 PM
scott's85T/A
Nov 6, 2002 07:27 PM
