Engine grounds is there an order ??
Old May 20, 2023 | 01:28 PM
murphymckenna's Avatar
Car: 1986 Camaro Z28 Iroc-z
So just a quick question I have an 86 TPI and the engine grounds are 6 in total 3 on each side ? Also there is one griund that has teeth to bite into when it's screwed down, so my question is should I put this one ground (with the teeth) in between the other 2 ? Or should I start with that 1 ? Or does it matter ?
Old May 20, 2023 | 01:58 PM
ULTM8Z's Avatar
Re: Engine grounds is there an order ??
Mechanically the one with the teeth should go first to bite into the metal. Bit electrically it doesn't matter.... ground is ground.
Old May 20, 2023 | 03:10 PM
T.L.'s Avatar
Car: '83 Firebird (T/A Clone)
Axle/Gears: 10-bolt/3.73 ..
The "teeth" go against the body...
Old May 21, 2023 | 01:28 AM
Thank for the advice I did the teeth engine side and boom everything seems to be working fine ! Minus the fuel pump.
Next question which pin on the bulkhead(C100) is for the fuel pump, im trying to trace it out because i only have 8.5 volts going to it, so I'm checking all the wiring. i have an 86 iroc if I didn't mention that before
Slowpoint0
May 20, 2012 01:09 PM
Smitty14
May 25, 2009 09:29 AM
firebird896
Dec 26, 2007 08:16 PM
91TA
Aftermarket Product Review
Sep 13, 2001 10:08 PM
