dome lite stays on
Old Jun 2, 2023 | 05:18 AM
buddybuddy's Avatar
dome lite stays on
I removed the passenger door to work on it and the dome lite stays on, I depressed the door pushbutton but still stays on. Is there some kind of contact that the door makes when it is closed, other then depressing the button, that completes a circut for the dome lite?
Old Jun 2, 2023 | 07:27 AM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
Re: dome lite stays on
Unscrew the plunger and make sure the wire leads are still on it. They tend to snap off.
Old Jun 2, 2023 | 09:29 AM
battmann's Avatar
Engine: LG4 / turbo LQ4
Transmission: 700R4 / 4L80E
shouldn't you unplug the connector before unscrewing these? won't that twist the wires? can't remember how these work to know if the whole piece spins or not. better to double-check so you don't break a wire if it's not already.
Old Jun 2, 2023 | 09:32 AM
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
You may be right actually. I just replaced mine and I cannot remember.
Old Jun 2, 2023 | 10:35 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
IIRC, the headlight switch can also activate the dome light.
RBob.
Old Jun 2, 2023 | 11:04 AM
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
RBob.
I totaly forgot about this, For the camaro's the headlight **** can be turned to put on the dome lamp. Make sure it is not on.
Old Jun 2, 2023 | 11:25 AM
buddybuddy's Avatar
did that , I removed the wires and unscrewed the plunger and checked them for continuity, they seem good, Will check the headlight switch, thanks.
buddybuddy's Avatar
Thanks will try that.
Blue_Thunder
Jun 7, 2016 06:27 AM
khozzmo
Jun 23, 2010 10:45 PM
John 89 Formula
Mar 29, 2006 07:37 PM
