Early cruise control with manual picture request.
Old Jun 24, 2023 | 11:54 AM
wildjeff's Avatar
Car: 1983 Trans Am
Engine: L69 5.0L HO
Transmission: Manual
I’m adding cruise control to my 83 T/A with manual. I have the parts but it would be helpful to see how the install looks. If anyone has an early thirdgen with manual transmission and cruise control, can you post a few pictures from under the dash showing the pedals switches? My biggest question is to see the clutch/brake pedals and how the cruise control switches setup.
Old Jun 24, 2023 | 02:47 PM
Dens71TA's Avatar
Car: '82 Recaro T/A, '71 Trans Am
Engine: 305CFI/455HO
Transmission: TH700R4/M22
Axle/Gears: 3.23/3.42
Re: Early cruise control with manual picture request.
There are two switches on the brake pedal. A gray combination brake light/cruise cutout switch and a black vacuum vent switch.
Clutch pedal has a combination cruise cutout/vacuum vent switch. I'll see if I can get some pictures later.
Old Jun 24, 2023 | 02:55 PM
wildjeff's Avatar
Car: 1983 Trans Am
Engine: L69 5.0L HO
That would be awesome. I have discovered I may be missing two parts. There is a specific manual pedal and I will need Cruise Control Vacuum Release Valve, part number 407437. The clutch pedal has a tab that contacts the switch, I think i can add a tab that will work. Finding the Release Valve may be a bit more tricky.
stealtht/a
Aug 19, 2009 03:13 PM
IroczInOz
Jul 21, 2005 11:10 PM
5SIZ
Apr 24, 2003 12:48 AM
Deck man
Jul 1, 2002 11:32 PM
