Wipers 2inch move only work on high
Car: 1988 Trans Am GTA
Engine: 5.7 L98
Axle/Gears: 3.77
I saw alot of threads on it, but no one came back after they fixed this issue. My wipers only move 2 inches and only work on high. I have tried two different wiper motors and circuit boards.
Wiper Switch is new.
Multifunction switch is new.
Car: 1989 Firebird
Engine: 2.8 V6
Re: Wipers 2inch move only work on high
It sounds like it's pulling them out of the park position, and then going right back. Have you put a multimeter to the plugs to make sure the switch is doing what it's supposed to be doing? Even if you put a new one in, the wiring may be damaged somewhere between the switch and the motor. Did you just put a circuit board straight in, or did you put new capacitors on it first? It could be a broken solder joint on the board that isn't visible, or you could have just had bad luck and pulled a second board with and identical problem to the first.
Car: 1991 Z28 Convertible
Engine: 5.0 V8
Transmission: auto
I’m having the same issue with my 87 Camaro. I was in the process of changing out the wiper washer pump, only to find out the contacts inside the module were broken. So I ended up replacing the whole thing, and now I only have high and no intermittent wipers, and the other wipers only moved 2 inches. I cannot figure out the linkage issue. See my attached video.
Engine: 5.7 L98
Axle/Gears: 3.77
Mine ended up also having a short in the motor connector.
I turned it on and just bent 1 at a time forward and back and i think it was the gray one I can't remember but it started working.
