Intermittent turn signals
Old Aug 1, 2023 | 09:06 AM
LT3D's Avatar
Car: '88 GTA
Engine: 5.7
Hi all, I've run into a problem with my 88 GTA where the turn signals only work intermittently. Sometimes they work as expected, sometimes one side works while the other side is solid (doesn't flash), sometimes both sides don't work, and sometimes one side works fine while the other side flashes very slowly. I also have an issue where the pop-up headlight sometimes need a tap to the module on the firewall to pop up, not sure if that is related.
What could cause this issue?
Old Aug 1, 2023 | 12:18 PM
vorteciroc's Avatar
Top Answer: 1
Re: Intermittent turn signals
delete
87IrocMan
Oct 7, 2009 01:11 PM
SumDumbGuy
May 21, 2007 06:05 PM
Trans-it
Jan 13, 2005 06:59 PM
Bruce89TA
Mar 26, 2003 08:46 AM
