ECM interchangable
Old Sep 15, 2023 | 12:39 AM
puggs's Avatar
Car: 1986 Camaro IROCZ
Axle/Gears: 323
ECM interchangable
Hi
I have a 1986 Camaro IROC-Z with a 305 TPI and TH400. It came with 2 ECMs. A short one marked 1986 TPI Manual in it and a longer one marked 1986 TPI Automatic. The longer one really won't fit in the space. Can I change the chip over, and will it work?
It seems to run ok how it is now, well after I got the injectors cleaned it does.
Old Sep 15, 2023 | 02:14 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: ECM interchangable
Never heard of two different length ECMs for that year/model. A picture of each along with the service number of each would be helpful.
RBob.
Old Sep 15, 2023 | 03:04 AM
puggs's Avatar
Axle/Gears: 323
The first 2 are the longer ones, and the others are the shorter ones. Strange, the smaller box seems to be from a VN Holden Commodore, which I would think would not work, but it does.
Old Sep 15, 2023 | 03:23 AM
puggs's Avatar
Axle/Gears: 323
I researched more and found the VN 5.0l was an Australian version of the 305. Might just keep it how it is as it is now running pretty well, and it may have some Australian-specific emissions control in it.
Old Sep 15, 2023 | 08:51 AM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
The 808 will work in place of a 165 just different baud rate.
2irocs
Mid-Atlantic Region
Sep 7, 2023 10:44 AM
Tuned Performance
Oct 3, 2021 10:43 AM
Dirty_Duke
Apr 29, 2021 08:14 AM
bblalock
Mar 3, 2010 10:00 AM
DEEPSOUTH90RS
Oct 30, 2000 10:28 AM
