High idle with new MAF
Hello. I have an 86 Iroc. 305 TPI. I recently just bought a new MAF. Car is at a buddies shop currently. Old maf wasn't working. Car ran better unplugged. You know how it works. Did ssome search. Alot of good feedback from the Wells MAF. wve 5s2640. Installed on car. Now has high idle. Anyone ome across this? Does tbe car have a learning phase?
Car: 1987 GTA
Engine: 5.7
Transmission: T5WC
Axle/Gears: 3:27
Re: High idle with new MAF
Definitely a learning period especially if you disconnected the battery for any length of time
Car: '18 Chev Camaro SS 1LE
Engine: LT1 6.2L
Axle/Gears: 3.91
There is not much of a learning phase. Idle should not be high.
How high is the idle compare to baseline in terms of RPM?
Maybe you have an air leak post MAF after installing the MAF.
Any scan tool available to see data stream?
Car: 1984 Camaro Berlinetta
Transmission: T56 6-speed
Axle/Gears: 4.11 LS1 Rear End
Try to reset the IAC and TPS; Simple & it might help !
Read BOTH threads !
https://www.thirdgen.org/tpimod2/
http://www.gmtuners.com/tech/TPS_IAC.htm
Read BOTH threads !
