Ok, crazy idea.. Help please?
Old Jan 9, 2024 | 02:57 PM
IROCKMY90IROC's Avatar
Car: 1990 Iroc Z
Engine: TPI SBC
Axle/Gears: Borg Warner 3.45
So I'm wanting to buy some H4 Headlights with Halos for my Iroc. I want the halos to turn on with my fog lights, AND flash WITH my turn signals. I know it would likely involve a relay or relays and some other wiring tricks, just not sure how to make it work. Anyone have any ideas? Thanks in advance, Collin
Old Jan 9, 2024 | 03:32 PM
vorteciroc's Avatar
Top Answer: 1
Re: Ok, crazy idea.. Help please?
What is so Crazy?
You need one SPDT Relay per Headlamp.
Old Jan 9, 2024 | 04:04 PM
ULTM8Z's Avatar
They probably have switch back halo LED headlights ready to plug in.
Old Jan 9, 2024 | 04:06 PM
ULTM8Z's Avatar
https://www.ebay.com/itm/33282196009...Bk9SR4yhj4SeYw
Old Jan 9, 2024 | 06:06 PM
Roorancher's Avatar
Car: 91 TA Vert WS6-94 TA Vert
Engine: 5.0/5.7 LT1
Axle/Gears: 2.73-3.42
I think halos are tacky, but that's me. I'm pretty much a purist. I have Hella replacement headlamps with H4 LEDs in both my TAs.
Old Jan 9, 2024 | 07:33 PM
Car: 1990 Iroc Z
Engine: TPI SBC
So this would cause the halos to flash at the same time as the turn signals? Not opposite?? That is what my ASE teacher told me it would do :P I'm fairly new to wiring, what would it look like? Thanks again, Collin
Old Jan 10, 2024 | 09:52 PM
Car: 1990 Iroc Z
Engine: TPI SBC
BUMP
Anyone?
Old Jan 11, 2024 | 09:19 AM
VIZ28's Avatar
Car: 1989 RU7 1LE / 1997 RS
Engine: 305 TPI / 3800 Series III
Transmission: T5 / T5
Axle/Gears: 3.45 / 3.23
Sounds like 4th gen DTRL module and wiring diagram is what you are looking for.
Grab one from a wrecker with the connector and a length of leads.
Old Jan 11, 2024 | 09:59 AM
ULTM8Z's Avatar
Are you intending your halos to be both white for DRLs and yellow for turn signals? If so, then see the ebay links I posted above.
if your halos are permanently yellow and you simply want them to flash with the turn signals, then get this module.
https://www.ebay.com/itm/33456345317...Bk9SR8SQ1pOfYw
Run the white wire to your fog light switch. Then route the wire to the turn signal wires.
Flamingo
Feb 15, 2023 11:09 AM
90FirebirdTA
Sep 19, 2011 03:11 PM
Gambit69
Apr 18, 2004 07:34 PM
GreyFox
Feb 22, 2004 01:22 PM
