ecm control?
Old Jan 16, 2024 | 06:06 AM
Evilokc's Avatar
Car: 1991 base firebird
Engine: tbi 305
ecm control?
i have a 91 305 throttle body injected car. im about to start my engine swap. im changing the injection type and will be using a holly HP ecm. my understanding is that the factory ECM only controls the fuel injection. i want to verify this so i can simply remove the ecm and factory wiring completely and replace it with my new setup.any suggestions from experienced engine swappers is welcome.
Old Jan 16, 2024 | 06:47 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: ecm control?
Fuel injection, spark timing (distributor), emissions equipment (AIR, EGR, CCP, closed loop), fuel pump, and the TCC lockup.
RBob.
Old Jan 16, 2024 | 07:01 AM
BBCSwap's Avatar
Engine: SBC Dart 400 Holley 750 Carb
Axle/Gears: 28 spline 323 gears
Re: ecm control?
The ecm does a few things. It controls the TCC lockup. The coolant sensor by the thermostat is connected to the ecm to turn the fan on. It might do more.
Old Jan 16, 2024 | 07:39 AM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: ecm control?
tbi ecm doest’t have fan control. There is a cylinder head temp switch on passenger side head that controls the ground side of the relay .
Old Jan 18, 2024 | 06:26 PM
Evilokc's Avatar
Engine: tbi 305
Re: ecm control?
okay good. i will have to look at the tcc lockup but other than that the holley is set up to control everything.
Hello, Michael
Jul 14, 2023 11:54 PM
orangecamaro
Jan 20, 2015 07:16 AM
eric305TPI
Nov 13, 2004 04:38 PM
