1988 700R4 speed sensor
Old Jan 21, 2024 | 02:14 PM
isaiah04's Avatar
Car: 1988 firebird
Engine: 305 TBI
I have an 88 TBI with a 700R4 behind it and the speedometer quit working. i get no signal out of the speed sensor while driving and I'm sure that's the issue. I cant find a single one for sale anywhere, its the type with the connector in the middle, and i haven't taken it apart but it should have a gear inside the tail shaft housing. Does anyone know of a way to convert it to a different type of sensor so i can still have the speedometer and torque converter lockup? I have seen kits that would convert a cable to an electrical signal but i am not sure what PPM i would need. everything ive seen is listed in PPR.
Old Jan 22, 2024 | 11:15 AM
John in RI's Avatar
Car: 1984 Camaro Berlinetta
Transmission: T56 6-speed
Axle/Gears: 4.11 LS1 Rear End
Re: 1988 700R4 speed sensor
What's your rear end gear ratio ???
I *might* have a factory electric speed sensor that will work. There are different versions depending on the speedo gears that need to be used. This pic shows the speedo gear tooth count the sending unit will work with:
TylerSteez
May 31, 2015 06:44 PM
JerseyMark
Dec 14, 2008 02:00 PM
wilbur2402
Oct 26, 2008 11:40 AM
