First Post! Need some thoughts and opinions on some broken wires.
Old Mar 1, 2024 | 12:23 PM
Klynsma76's Avatar
Car: 1986 Firebird
Engine: 6.0 LQ4
Transmission: TH350
Axle/Gears: 10 bolt 3.43
Hi Everyone!
First post here but I picked up a 1986 Firebird from one of my buddies and I'm going through some stuff and fixing what the owner before him messed up. I need some help identifying some parts as I'm not 100% what they are.
It is a 350 sbc with a th350
Im pretty sure this is the fan relay that was butchered, also ate there not supposed to be other relays on this panel?
Pretty sure this a vacuum sorce for the hvac? I broke the line going towards the blower motor.
I am doing my own gauges but im trying to keep the turn signals and high beam indicator so im wondering if I need to replace or repair this as they had installed an aftermarket speedometer and messed up the printed circuit.
I've gotten most everything else figured out, and have a bunch of small things to undo/fix.
Next major thing after these is I have to fix the trans coolant lines as they are leaking.
Old Mar 1, 2024 | 12:36 PM
ACebell's Avatar
Car: 1983 Camaro Z28
Engine: Originally LU5, but now Carb'd
Transmission: TH350
Axle/Gears: 323
Re: First Post! Need some thoughts and opinions on some broken wires.
Welcome aboard. Yes, the second picture is the vacuum source for the HVAC system. The input source of vacuum is the intake manifold. On the carburetor versions, it is pulled from the same source as the power brake booster. The output travels through the firewall by the HVAC box to the back of the climate selector.
Old Mar 1, 2024 | 12:54 PM
Klynsma76's Avatar
Car: 1986 Firebird
Engine: 6.0 LQ4
Transmission: TH350
Thanks I will look into it now.
Old Mar 1, 2024 | 01:05 PM
Klynsma76's Avatar
Car: 1986 Firebird
Engine: 6.0 LQ4
Transmission: TH350
I forgot one more thing.
Is this the connector for the lower dash buttons?
Old Mar 5, 2024 | 01:24 PM
John in RI's Avatar
Car: 1984 Camaro Berlinetta
Transmission: T56 6-speed
Axle/Gears: 4.11 LS1 Rear End
Yes it is,.....
Any option buttons located on the dash bezel trim panel will require a short 'connecting' harness from the option button(s) -to- that square plug in the dash housing.
Old Mar 5, 2024 | 01:27 PM
Klynsma76's Avatar
Car: 1986 Firebird
Engine: 6.0 LQ4
Transmission: TH350
Ok thanks!
ChevyKen
May 29, 2022 05:05 AM
I_R_O_C_Z_2_8
Jul 13, 2016 09:25 AM
dspencer24
Northern California
Oct 22, 2007 09:20 PM
Z_wonderer
May 20, 2007 09:58 PM
DeathZ
Pacific Northwest Region
Sep 13, 2001 01:35 PM
