Amp is killing battery
So this has just happened recently been running this amp for a few years now....So the other day I went to the gas station and went to start my car and the battery was dead so I got jumped off got it home. Next morning same thing dead battery so I went and got everything checked it was all good said I had a parasitic draw. So I got to looking at amp with car off when on it lights up blue...So no lights on the amp so I disconnected the remote wire and ran a multimeter to amp red and black terminals and I was getting 12 volts is my amp shot? Any way to test this further? I do have a stock head unit so my remote wire was wired to a cigarette lighter but that cuts off when car is off.
Car: 1986 IROC Z
Engine: 5.0 TPI
Axle/Gears: 3.23 Posi
Re: Amp is killing battery
BTW, parasitic draw is measured in current flow, not voltage. This vid will explain how to track down the offending circuit in your car's electrical system.
Car: 1984 Trans AM
Transmission: 700-4r
Using a multimeter was how I discovered that my radio was causing a parasitic draw on my battery & killing it. I had an electronics repairman resolve the situation. No more draw.
Car: 15 Ram, 88 IROC, 92 RS
Engine: 5.0
Axle/Gears: 3.42 (4th Gen)
The large positive and ground should have constant power. The remote is the only one that will be switched. If you can measure voltage at the remote terminal with the blue wire disconnected then the amp is bad.
Car: 1984 Camaro Berlinetta
Transmission: T56 6-speed
Axle/Gears: 4.11 LS1 Rear End
it’s not a switched power source.
Maybe run the remote wire to the YELLOW switched power to the factory radio harness,…. That wire leads to the radio fuse; you could also ‘tap’ into the radio circuit at the available port in your fuse box.
Hawkeye1980
Mar 3, 2024 03:04 PM
