Manual swap issues
Manual swap issues
So the 87 camaro i just bought was incompletely manual swapped and the ignition is stuck in the on position and i can crank the car but cant shut it off how do i fix this problem? Also they didnt wire the break lights in either. And when i got the car the clutch line from the master to the slave cylinder was cut any idea where i can buy that clutch line? Will the vehicle operate properly without a manual ecm?
Car: 1989 Trans Am
Engine: sp357
Transmission: TKX
Re: Manual swap issues
https://www.thirdgen.org/forums/tran...mare-swap.html
Making multiple threads about the same issues is a good way to get ignored. The membership here is insanely knowledgeable and every question you have has been discussed multiple times over the past 20+ years this forum has been around. Two of use have already responded to your first thread on the subject. Many of us are willing to help, but it's going to take some time and patience and effort on your part (searching and reading this forum) to work through the issues. I have easily spent 3-4x as much time just researching here than I have actually spent wrenching on my car. If you aren't willing to put in that kind of effort you're going to need to pay someone else to figure it out for you.
Mpaul3355
Jun 4, 2011 09:23 AM
