How to tell if your camaro came with auto or manual stock
Old Jun 2, 2011 | 08:41 PM
Mpaul3355's Avatar
Title says it all how do I know if it was a stock manual transmission or a swap help
Old Jun 2, 2011 | 09:38 PM
pleiku10's Avatar
Re: How to tell if your camaro came with auto or manual stock
There will be a hole in the transmission tunnel for the shifter if it had a manual
Old Jun 2, 2011 | 10:35 PM
Mpaul3355's Avatar
I ment the other way auto in to manual
Old Jun 2, 2011 | 10:37 PM
nickhil2003's Avatar
Car: 1982 trans am
Transmission: 4 speed
Axle/Gears: 3.08
any shoddy work hanging the clutch peddle, master cylinder, and look at the hole that was cut for the shifter
Old Jun 2, 2011 | 11:49 PM
91 1LE's Avatar
Car: '91 1LE
Engine: 377 w/Stealthram
Axle/Gears: 3.42 Torsen
Is there a button on the steering column for the key release? That is a manual column and most people don't swap them. Or look at the RPO codes.
Old Jun 3, 2011 | 07:45 AM
Mpaul3355's Avatar
Wht the rpo code for manual
Old Jun 4, 2011 | 09:23 AM
stealtht/a's Avatar
Car: 1985 Trans Am T-Top
Transmission: T-5 5 Speed
Axle/Gears: 3.42 posi 1LE 10 bolt
you can see the hole in the tunnel from below. seriously, thats the best way to tell for sure. theres nothing in the VIn that will tell you. I dont know if there was an RPO code and its probably missing or wrong anyway.
84z96L31vortec
Aug 20, 2017 12:16 AM
Azrael91966669
25
Jun 20, 2017 04:04 AM
mustangman65_79
Aug 12, 2015 06:39 AM
84z96L31vortec
Aug 10, 2015 08:27 PM
Leggman1
Aug 6, 2015 04:15 AM
