Speedometer Issues
Old Apr 8, 2024 | 04:28 PM
carlos64030's Avatar
Car: 1991 Trans Am GTA
Speedometer Issues
I have a 1991 Trans Am GTA and I'm having random speedometer issues where it'll just stop working. I've already changed the Vehicle Speed Sensor and that didn't solve the issue. I already know it's not an instrument cluster issue because when the speedometer stops working, so does the cruise control. What else should I check? A possible short in the VSS wire?
When I say random problems, it's like REALLY random. For example: one day the speedometer wouldn't work at all and then not a single issue the next day. Today, it started off not working and then it did later then stopped again.
Old Apr 8, 2024 | 04:42 PM
blacksunshine'91's Avatar
Transmission: Pro-built 700R4
Re: Speedometer Issues
When you replaced the VSS, did you inspect the gear on the output shaft to see if the teeth on it were still good?
Old Apr 8, 2024 | 07:12 PM
topduarte's Avatar
Car: 92 Heritage Camaro Z28
Transmission: auto
Axle/Gears: 3.23 Limited Slip
It is probably the electronic resistor leaking in the electronic circuit board that controls.
This happened in my 92 z28
Old Apr 8, 2024 | 08:09 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
I hate when resistors take a leak on circuit boards.
Old Apr 8, 2024 | 09:34 PM
The transmission was fully rebuilt a few weeks ago. I ASSUME all of that was taken care of.
Old Apr 8, 2024 | 09:35 PM
Where would that resistor be located?
Old Apr 9, 2024 | 07:14 AM
Engine: Lb9
Transmission: M20
Is the check engine light coming on and ecm storing a code 24 ?
tpi ?
Old Apr 9, 2024 | 09:11 AM
tpi ?
The Check Engine Light has been rendered obsolete because my car's power train is managed with the Holley HP EFI ECU. For the record, I was having this speedometer issue when my car was bone stock.
Old Apr 9, 2024 | 06:16 PM
Engine: Lb9
Transmission: M20
Does the Holley get a Vss signal you can watch or datalog ?
do you have a Vss buffer ? Cable drive speedometer ? Dakota digital sgi5 or 100bt ?
insomniac
May 5, 2020 06:24 PM
spddmn
Jan 15, 2008 06:25 PM
Lex87
Feb 1, 2006 05:11 PM
BillL62000
Jun 23, 2003 09:03 AM
