1992 Camaro RS needs interior wirning
Old Apr 15, 2024 | 04:50 PM
CamaroCris's Avatar
Car: 1992 Camaro RS
I have a 1992 camaro that has been hacked up a bit on the interior wiring side. rather than chase shorts and or cut wires i would rather install a new wiring harness, I can only do it from 90-92 because of the gauges correct? I have no power windows or rear hatch opener. If you have a harness for sale please contact me.
Old Apr 15, 2024 | 06:21 PM
ratfink6923's Avatar
Car: 15 Ram, 88 IROC, 92 RS
Engine: 5.0
Axle/Gears: 3.42 (4th Gen)
Re: 1992 Camaro RS needs interior wirning
I have a power window 92 harness still in car that hasn't been molested aside from the stereo connections.
where are you located?
Old Apr 15, 2024 | 06:30 PM
CamaroCris's Avatar
Car: 1992 Camaro RS
Nice! I would be into one with power windows and power seats if im correct im trying to make my RS into a Z28 clone. I am located in denver,co
Old Apr 15, 2024 | 06:56 PM
Engine: 5.0
This was a manual seat car with rear defrost. Adding the power for the seat is relatively easy.
if you don't come up with anything let me know, I'd have to pull it yet.
Old Apr 15, 2024 | 09:15 PM
CamaroCris's Avatar
Car: 1992 Camaro RS
okay that sounds good to me, was the car an auto or a manual?
Old Apr 15, 2024 | 09:32 PM
Engine: 5.0
Automatic car. 305 tbi. Power windows/locks/hatch release. Rear defrost. Cruise control. Intermittent wipers. Standard dome light. Base radio/rearview mirror (non lighted) vats car obviously. I'll throw in the vats and cruise modules if you'd like, I don't need them.
the stereo harness I think was cut. I have to check.
Old Apr 15, 2024 | 09:35 PM
CamaroCris's Avatar
Car: 1992 Camaro RS
do you know if it would make a difference since my car is a manual? highly doubt it but just want to make sure i buy the right harness the first time.
Old Apr 15, 2024 | 09:48 PM
Engine: 5.0
There will be different connections for clutch pedal and backup lights. The backup lights may be engine harness side though, I'll have to check.
Old Apr 16, 2024 | 10:50 AM
CamaroCris's Avatar
Car: 1992 Camaro RS
Didn't think about that let me see if i can find one that will go directly into my car, if not ill buy yours and adapt those connections from my original harness.
Old Oct 16, 2024 | 03:01 PM
Purple 92 SS's Avatar
Car: 1992 Z/28, 2000 SS, 1968 RS/SS
Engine: 355 Built a bit / LS1
Transmission: T-5 / A4
Axle/Gears: 4.10 / 2/73's
i'm doing this right now with my 92. it was a bone stock rs with no options, i've bought a 90-92 dash harness from hawks, for a loaded 5.0 v8 z/28 car including the power window/locks, and mirror harness that plugs into the dash harness. well the first time they sent me the manual harness but forgot the window/lock/mirror add on harness, so they sent me another complete harness, except this time the second harness was for an automatic car. I only needed the window/locks/mirror addon harness so i unplugged it from the automatic harness, and used the manual harness they originally shipped me to replace the old original hacked up harness that came in my RS. I"ve got it totally wired up now, and just about ready to go back into the car as far as the dash is concerned. I have alot more things to wire and fix up before im ready to put it back together though... all that said, i still have a spare automatic dash harness from Hawks.. if they dont want it back and you want it i would sell it to you at a considerable discount from what hawks sells them for. just know this, swapping the entire dash harness and what not, is no small job. its been a TON of work so far, but its also so far been very rewarding as i feel that my car is finally going to be right wiring wise.
Old Oct 17, 2024 | 08:38 AM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
Which harness specifically is hacked? Is it the dash harness or just areas that extend out of it in the cabin of the car (seats, fuel, windows, etc).
CamaroCris
Interior Parts Wanted
Mar 25, 2024 05:49 AM
Whtrow91
Apr 11, 2018 03:28 PM
jgbrown32
Jun 11, 2017 06:52 PM
upandcoming
Sep 22, 2009 10:18 AM
Soupjmpr
Oct 30, 2007 03:21 PM
