Some form of electrical issue...
Old Jun 30, 2024 | 05:42 PM
JacktheVagabond's Avatar
Car: 1989 Camaro RS
Hi all. I have a 1989 Camaro RS. Check engine light comes on intermittently, usually after rapid acceleration or sustained highway speeds. Outside temp/ humidity/ weather does not seem to affect. I have a cheap little 12 pin code reader I bought off of amazon, and it's giving me the following codes-
43) Low voltage detected to the EST circuit
51) Computer problem/ bad PROM circuit/ ECM/PCM failure
53) System voltage too high/ EGR system fault/ Alternator voltage not normal
If anyone has any ideas what could possibly be causing this combination of symptoms, please let me know. I know the battery and MAP sensor are good, I replaced the MAP and just got the battery checked today. Thanks!
Old Jul 3, 2024 | 02:40 PM
JA411's Avatar
Re: Some form of electrical issue...
Which engine? 43 usually ignition module or ECM. 51 is usually prom and or ECM. I don't remember 53 as being EGR?
Joe
Old Jul 13, 2024 | 10:04 AM
Car: 1989 Camaro RS
I don't know much about the engine, I'm still very much learning, but I believe it to be a LO3 based on the 8th digit of the VIN being E.
As far as what the codes mean, I was just reading off of the little book that came with the code reader.
1986 T/A
Aug 9, 2014 10:09 PM
thetaman85
Dec 20, 2009 07:36 AM
87_TA
May 30, 2007 12:45 PM
dp149
Mar 16, 2004 11:28 AM
Rat 427
Jul 29, 2002 06:17 AM
