Air conditioner doesn’t work unless I turn the key a little past run
Old Jul 12, 2024 | 04:55 PM
Trentl's Avatar
Car: 1992 Camaro rs
Engine: 305 Tbi
Transmission: Automatic overdrive
So my 1992 305 camaro has a ton of electric problems but I’m trying to solve them one at a time
My air conditioner hasn’t worked since I bought my car however if I turn my key just slightly past run it starts blowing nice cold air. I am wondering if it is the ignition switch or the actual lock itself or something else entirely. If it helps I was recently forced to do the vat’s delete with a resistor
Old Jul 12, 2024 | 05:51 PM
OrangeBird's Avatar
Car: 1989 Firebird
Re: Air conditioner doesn’t work unless I turn the key a little past run
Originally Posted by Trentl
...... if I turn my key just slightly past run it starts blowing nice cold air......
Only two possibilities here, either your ignition switch is out of adjustment, or it's contacts are all pitted & nasty(if everything else but the A/C works, I'd bet on pitted & nasty).
For clarity's sake, it's the black square on top of the steering column with the blue plug plugged into it in this pic;
Old Jul 12, 2024 | 05:52 PM
Try adjusting the ign sw.
Lower the column. It's down near the firewall, on top, has 2 connectors with mostly big fat wires. 2 ¼" hex head screws (maybe 7mm in your year) hold it in place; loosen; slide the switch up the column a bit, maybe 1/8"; tighten; put the column back up. Lather rinse & repeat as necessary.
VATS is not relevant to this.
oBEA5To
Jan 26, 2016 10:50 PM
91camarox
Apr 23, 2012 11:25 PM
maroon88iroc
Dec 27, 2005 04:16 PM
Mkos1980
Nov 14, 2002 07:52 PM
breathment
Feb 11, 2002 09:52 PM
